Perform the following procedure to view the power consumption of the modules in the chassis.
- Select Chassis.
- Select the Power Consumption tab.
Power Consumption Field Descriptions
Use the data in the following table to use the Power Consumption tab.
Name |
Description |
Index |
Specifies an index value that identifies the component. |
PowerStatus |
Specifies the power status: on or off. |
ConsumedPower |
Specifies the actual consumed power for the slot. This value is 0 if the power status is off. |
SlotDescription |
Specifies the slot number. |
CardDescription |
Specifies the type of module in the slot. |
